2019 Estate Lux Xcellence - boot won't lock
buffeh
11
Probably wouldn't have noticed this if I wasn't playing around trying to fix the common "Seat logo handle doesn't spring back again" issue - which I fixed in seconds with just WD40 - but noticed that the boot can be opened with no issue even when the car is meant to be locked!
So to clarify - the boot closes fine and stays closed. It opens fine with a nice sounding correct noise when I pull the handle or press the button on the remote. However it does not lock, I can lock the car and the boot can be opened with the handle as if the car were unlocked.
Have looked around the an answer on these forums and this appears to be a less common problem at least with the newer cars. Most complaints are that the boot won't shut properly, or won't open properly.
This is the lock that's in my car, confirmed via the part number printed on it: https://www.onlinecarparts.co.uk/esen-skv-18556691.html
buffeh
11
To add to this here is what it looks like under the cover in my boot. Is something meant to be connected to the white thing arm thing!?
buffeh
11
oh my god I'm so stupid
I just got this car and apparently it has keyless entry, which I only just found out
everything is working exactly as it's meant to
I would close thread but I'm not sure that's an option, apologies for my stupidity!
  • Haha
Reactions: Cadabena and Walone
