2019 Cupra 290 Res Delete Done!!
Omi
14
GPF has a temperature sensor in it, and right behind the GPF is a pressure sensor. One so it can do the regeneration, the other so it can throw a fault if it’s blocked. Shouldn’t be rocket science to code out or fix safe values.
Thinking about it I might have the 2 arse-first. ;)
Kirky
Copper Cupra Advocate
Apr 10, 2019
1,042
497
I dunno where you are, but a local place to me near Edinburgh offered to supply and fit a Res Delete for £80, then when I wanted it removed, they would refit and weld resonator back in place for £40.
Did you end up getting this done. If so how has it been?
