2007 BMW 3 Series Saloon E90 330D M Sport [DPF DELETE]
Sep 18, 2009
2,443
Shropshire
added a few decals today.
My AC Schnitzer rep top spolier has an indent in it for a badge. would of been better if it wasn't there, but it is, so i filled it with a AC Schnitzer decal, like the original would of had. not a perfect fit, but you wouldn't know unless you went in right close.
Also added a ODK detailing splat sticker to the bottom o/s of the rear window
2,443
Shropshire
Had my 4 wheel laser alignment done by a company that use the Hunter Alignment machine (same as BMW).
Steering wheel wasn't centered and handling was all over the place. The alignment print out showed why with 10 adjustments needed to the camber, caster and toe.
Feeling much much better to drive now
Also fitted a genuine BMW Natural Air starter kit vent mounted air freshener
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Like the decals mate :)
The handling looked well off, but it must feel wired now! Good stuff.
Sep 18, 2009
2,443
Shropshire
Did feel loads better after the alignment lol
Bump...got myself one these now and im loving it...
They really are cracking cars. Mines mapped to around 275 BHP, runs to 60 in around 6 seconds and returns 45mpg+ on a motorway journey....cant really complain.
I've looked at a BMW 335D and I was soooo tempted worried about the RWD in snow though.
Only thing that put me off the 335d was its Auto only, otherwise i would of got one. Having said that, your only real option for big powered powered diesels seem to be auto due to the large amounts of torque that would go through a manual clutch and gearbox.
I was looking at the new Xdrive 335D, there Auto only but do 0-60 in like 4.8 seconds and return 50+MPG, thats just insane.
Ive yet to try mine in the snow but it will be horrid, had a little spin when it was icey last year so cant imagine how poor it would be in the snow.
Danny-
181
Peterborough, Uk
Yeah my dad had a E90 318i and had it for 6 months during the winter and said he would never go back to RWD lol..
I don't mind the Auto on the 335 I believe they're DSG?
holmefield
Forever messing with cars
Oct 20, 2013
578
Can I ask how hard was it to remove the ally interior trim bits, I've loads of carbon wrap so fancy giving the trims a retrim.
Was the centre consol bit around the handbrake and gear knob hard to remove + does the ash tray cover come off from the plastic backing?
Loving your car, Emaps for me around feb/march next year...
holmefield
Oct 20, 2013
578
Sep 18, 2009
2,443
Shropshire
Hi mate, most of the trim just pops off with a plastic prise tool and yes the ashtray cover will come away from the middle console part.
Emaps did mine and so far its been great. running it for about a year now.
2,443
Shropshire
Well after a year’s ownership id thought i write a little review
PERFORMANCE
For a Diesel it’s great. The 6 cylinders make it sound nothing like a 4 cylinder diesel, sound from the cabin while driving, sounds pretty beefy if I’m honest. Performance from the stock 231 BHP and 500NM torque will see 0-62 in 6.7 seconds and tops out at 155 MPH, having mine mapped to around 275BHP and 600NM torque I’m seeing around 0-60 in about 6 seconds, the pull from the stupid amount of torque is insane. Revs max out at 4500rpm, which if you hit it, actually sound and fell like 6000rpm in petrol, gear changes from the 6 speed manual box are nice and tight.
ECONOMY & RUNNING COSTS
Considering the performance the economy is great. I often see 42-47 MPG on a 150 mile journey (120 miles motorway & 30 miles urban traffic). Costs me around £80 to fill the tank with Shell V-Power (£1.40 a litre) and I should see about 550 miles for that. Tax is about £200 a year and cost me around £400 a year to insure. As far as servicing goes it uses Long life Castrol Edge oil so can go 19,000 miles before an oil change, but it takes 7.5 litres of oil which is about twice the amount of oil for a normal car so sort of cancels out the long life bit lol, just means you don't have to change it so often. Cost of oil and pollen filters about the same as on any car, about £5-£10 each. Changing the air filter is a joke and takes around 1-2 hours to complete by removing most of the engine plastic trims, covers and strut brace to get to it. Bimmers tend to run wider rear rims, and being RWD the more expensive back tyres wears out quicker than the fronts. I’m paying about £320 for a set of 19" Falken rears. Also be aware that most electrical things you upgrade or change in a modern bimmer need coding to work which makes retro fitting anything pretty tricky, but there are lots of people\companies out there offering coding services. Having a pair of folding mirrors coded can cost you in the region of £100-£200, that’s just for the coding :shock:. General BMW spares and fitting at the dealers or specialist also come in quite pricey to anything else I’ve owned (Ford, Fiat, Seat and VW)
IINTERIOR
I was quite disappointed with the standard interior, the black Dakota looks grey and I hated the brushed aluminium trim that was splattered all over the dash and door cards so carbon wrapped them. Standard seats look boring but quite comfy, changed the fronts for a set of reclining Cobra Misano seats . Good leg room in the front and back, even if you’re tall like me and have your seat far back, there’s still a good amount of leg room for the rear passenger behind you. The iDrive is pretty damn good except for the sat-nav which looks graphically dull and is running 2007 maps. I Dash mount my iPad mini 2 and run the tomtom app with traffic and camera subscriptions which is far better than any built in sat nav you’ll find in any car so it’s not really a problem for me. The black cloth roof lining an pillars are a nice touch and everything seems very solid and well built, no rattling. The M sport springs are quite stiff so give a bumpy ride for stock springs but is easy to live with. One thing I found quite annoying is its rare to find a E90 Saloon with folding rear seats, which means your limited to just the boot space, gone are the days of packing a Ikea kitchen in the boot like I could on a hatchback, lack of rear wiper is sometimes annoying too. Cup holders are very good and don’t hang over your head unit which means no spilt coke over your stereo. Overall the interior is roomy and well laid out. The car is packed with some useful stuff though like auto lights and rain sensors, electric windows front and back, heated front and rear windscreens, dual climate control, cruise control, auto dimming mirror, hands free Bluetooth with voice control.
EXTERIOR
I found the M sport look quite pleasing to the eye, only thing i found quite dated on the Pre-LCI was the red halogen rear lights with the silly white bits in, I changed the rear lights and tailgate for the LCI LED rear lights and tailgate and it gives it a much fresher, aggressive but modern look. Exterior led welcome lights are a nice touch, as are the gloss black mirror base plates and window edging. M Sport models give you a sportier looking front and rear bumper as well as side skirts and lower sports springs.
HANDLING & BRAKING
I found the handling of the car quite poor when i picked it up, but then realised it was running budget non-run flats. Changing the tyres to a decent brand improved the handling in the dry and wet no end, and standard factory fit m sport springs and front strut brace help provide decent grip when approaching such things as roundabouts at speed. I’ve found the standard brakes to be pretty good, rear discs are quite large too, maybe because it’s RWD.
ICE
I found the iDrive very useful giving all sorts of information about the car. It monitors everything, your tyre pressures, brake pads, DPF and tells you how much life is left in the serviceable components. Also acts like a computer letting you change most of the settings for the car like speed limits, lights, indicator timings, daytime running lights, detailed trip computer, sat-nav etc. DVD drive lets you play DVD mp3's but not DVD movies, well at least not on the Pre-LCI version. Has Bluetooth for hands free calling which paired well with my iPhone 5S giving me all my contacts on the iDrive. Also has voice control so you can call up menus on the iDrive. Visual parking sensors with distance control on the iDrive is also useful, not only can you hear when your close to something the iDrive displays how far away a particular item is and where about it is. Sound in general is pretty poor. The BMW professional 4 speakers and 2 small subs under each seat isn’t really enough to create a decent surround sound and is severally lacking tweeters and better bass, which again is an option called Logic 7 which I’ve been told sounds amazing and tempted to retro fit this.
OVERALL
Has the perfect blend of performance, economy and space and I would say probably the best for its age in this field. It has a nice solid feel to drive and feels quality. They look good but doesn’t necessarily have the wow factor as there ae so many of them on the roads, can look better if you make them a little unique. My only disappointment with this car was the lack of extras that i would expect to be standard on a car of this calibre and with retrofitting being costly due to extra coding required I would recommend anyone buying one of these to get one with the extras such as Xeon lights, iDrive, folding mirrors, heated seats, sunroof, folding rear seats etc. I would defiantly get another one, possible the 335D Xdrive in auto next time around.
holmefield
Oct 20, 2013
578
Cheers, yep like you i've started the mods to my E90...i've plasti-kote my front grills gloss black, put 12mm wheel spacers on the rear..my alloys are OEM 189 18" bmw alloys there 8J fronts and 8.5J rear so now with the spacers it looks like a proper staggered setup I.E nice and fat @ the rear..
I wasnt to keen on my Ally dash inserts either so i've 4D carbon wrapped them today, just got the rear door sides to do and the lower gear stick surround and ash tray do you have to remove the gear knob? Mines a manual so hoping i dont have to completely strip the gear knob and gator off..
i've got yellow tint film for the front fogs, and have ordered some plasti-kote red glass spray paint for the rear lights, im waiting for my white Led interior bulbs to arrive from china @ the mo.
i kept looking and finally got the right spec as standard, it includes
Factory adative Xenons
Heat Lemon leather
Memory seats, with full electric options
Upgraded Hifi pack, the sound is mega
Electric sunroof!!!!
Electric folding mirrors
Split folding rear seats, as you said a must so i can @ least get Ikea stuff in now!
Split side centre arm rest
the list goes on.
i agree over the running cost verus peformance these things are quick.....keep the updates coming...
Sep 18, 2009
2,443
Shropshire
Heat Lemon leather
the list goes on.
will do mate. Congrats on that spec, thats what i sould of waited for. Sunroof and folding rear seats is pretty hard to find, especially in manual.
Do you have a readers ride ?
holmefield
Oct 20, 2013
578
Well carbon wrapped my lower centre console that surrounds the gear stick and handbrake....it was a right pig..
i've done quite a lot of wrapping now and im getting better/quicker but the odd shape + gentle rad + 3 cut outs in the middle of the console had me sweating took me around 90 mins to do as i wanted to do it right...gave up trying to get the ash tray cover off so just wrapped it in place and surprizingly the ash tray cover looks ok, i'll start a readers ride this week..
Next up is to red spray tint my rear lighrs using plasti-kote red glass paint, should be interesting...
Sep 18, 2009
2,443
Shropshire
Yes, I found the trim easy to get off but took me a good few hours to wrap them all aswell, I used a hair dryer to help stretch it in the difficult parts. Tinting rear lights ? Is yours the pre-lci and your tininting the White bits ?
holmefield
Oct 20, 2013
578
Yep mines a pre Lci its a 56 plate, with the spec I wanted Lci models were to expensive..yep im going to take the white inner lights out ( I've tryed wrapping them but they look crap ) & test spray them to see how they look / colour match to the outer lights...
Sep 18, 2009
2,443
Shropshire
Same reason i went pre-lci, LCI was just costing too much. I smoked my white bits and it looked rubbish, yours tinted red should look much better. Them white bits are the reason i didnt like the pre-lci rear lights.
