2001 Cupra Mk1 Replacement Remote Key Issues
Brettyboy
2,600
Exeter,Devon
Does make sense mine is'nt a cupra but it is 2001 & having same prob,would i be right in saying its the same with early mk4 Golf's ?
scrappydoo
I shall open all mine remote keys up and see what frequency they're operating at just in case one is a 433.
Thanks for the tips and I'll keep you informed.
scrappydoo
Well I've checked he keys and the two flip keys I have are 434mhz, but I've taken the other original leon keys apart but I'm unable to find where it states the frequency!
scrappydoo
Does anyone know how to decipher what frequency the original Seat remote keyfobs are? I have 3 of them and have no idea what frequency they run at as unlike the flip keys I can't find a clear identification for them.
scrappydoo
Yes mate as i have said (a few times) its 433 mhz if they don't work they are A, dead, or B, there is a problem with the pairing procedure.
Think you might be misunderstanding me. I know I need 433mhz fobs, but I don't know whether the 2 Seat fobs I have are 433mhz or 434mhz because there's no way of checking them it seems.
I do though know the 2 flip keys I have are 434mhz.
:confused:
Dec 31, 2007
1,479
Reading
To check whether it is 433 or 434, press the button to flip the key out. Then pop the screwdriver into the small slot under where the key normally sits. Separate the 2 halves.
I'm pretty sure on the back of the lower half of the bottom part (the bit with the buttons!), there is a load of text. Turn the key sideways and on one side in small lettering is 433/434.
At least on mine it did (a 434mhz).
I finally programmed mine this morn, took a couple of attempts though. Got the blade cut this afternoon, turns the ignition, but won't open the lock in the door! Need to get the transponder done now.
scrappydoo
Finding the frequency on the flip is easy and I have done it and they're both 434. To check the frequency on an old 2 button seat remote keyfob is more difficult. I've checked both keys and one I've discovered is 434mhz but the other I cannot find any identification so unsure if it's 433 or 434 but none of them will program! [:@]
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
We have got that far James,(Earlier in the thread) its the non flip key Scrappy's having problems with
