20,000 mile serice - brake fluid change?
Emm
269
UK
I’ve booked my Cupra in at the dealership for it’s 2nd year service this weekend.
I was told it would have a 20k miles inspection service, the pollen filter replaced plus the brake fluid changed.
On looking in the service book (page 14) under additional work, the pollen filter should be replaced every 2 years, but the first brake fluid change needs doing only after 3 years (or 125k miles), then every 2 years.
Surely based on the above I can defer the fluid change until next year?
alx_chung
Dark Lord of the Torque
Sep 11, 2006
1,538
In front of a PC....
Its recommended that the Brake fluid is changed after every 2 years. I got mines done at the 20K service as well and have to admit the brakes are working a lot better than they were. I would just get it done.
There have been a few posts about this before.
Alex
Emm
269
UK
Alex
Thanks for the reply Alex
Just curious over the discrepancy that dealerships are saying every 2 years and the maintenance programme book states brake fluid replacement after 3 years (or 125k miles), and then every 2 years after that.
599
Kent
Alex
Had mine done at 20k as well, if that makes a difference
ali831
103
hampshire
£55
I had the same at my stealer yesterday. They agreed the first brake fluid change is done at 3 years and then every 2 years after that. We only do approx 6,000 miles a year so they said it wouldnt be a problem. They charge £55 which includes all labour, parts and VAT.
BeezerDiesel
Minus a Diesel Beezer
Aug 3, 2002
1,852
Exeter
£55 seems very steep for a bf change. When I phoned around VW dealers for my Golf GTI (same chassis and running gear remember) they were quoting around the £43 - 45 mark. Had it done by my friendly local indie at £23 inc VAT (my car's out of warranty).
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Fluid change as a worst case scenario is a 2yr event, or sooner if your miles are higher.
It's all down to the hydroscopic nature of the fluid taking on more & more water. the more water you have, to worse your brakes are.
You should get it done by your 2yr/20k service....
Mar 30, 2008
621
Edinburgh
my brake fluid wasn't changed on the 20k service, but shortly afterwards i change my front brakes to a brembo setup and running racing brake fluid. Now i'll be changing brake fluid as regular as required.
Feb 12, 2006
625
North Lincolnshire.
They probably buy the brake fluid by the barrel.The change is prob only costing the garage a fiver and 15 minutes labour time.What a rip off for £45. £23 seems pretty fair price.
Feb 12, 2006
625
North Lincolnshire.
Does anyone really think the brakes will go spongey or is it just for the dealers to make easy money? I remember on all my old cars never changing the fluid once with no noticeable problems.
chrisboyle999
MFD3 for sale, inbox me.
Nov 28, 2006
1,838
Geordieland
yes. not only that the more water is absorbed the more likely it will boil making matters worse. the system will also start to corrode from the inside out.
chrisboyle999
Nov 28, 2006
1,838
Geordieland
from tinternet;
"The brake system uses a glycol-based hydraulic fluid. The fluid is "hygroscopic," which means it tends to absorb moisture over time (never leave a can of brake fluid open for this reason). Moisture lowers the boiling point of the fluid and causes internal corrosion in the brake system. That’s why the fluid should be replaced when brake repairs are made or every two years for preventive maintenance. There are several different types, based on the boiling temperature and other characteristics of the fluid. DOT 3 or DOT 4 is used in most passenger cars and light trucks. Use only the type of fluid specified by the vehicle manufacturer. Using DOT 3 in an application that calls for DOT 4 might create a safety hazard. DOT 5 brake fluid is different from DOT 3 and DOT 4 in that it is silicone-based. DOT 5 is NOT recommended for any vehicle equipped with antilock brakes - but it can provide long-lasting protection against corrosion for vehicles that are stored for long periods of time or are driven in wet environments."
chrisboyle999
Nov 28, 2006
1,838
Geordieland
How can a sealed braking system absorb water though?
also from tinternet;
"Glycol based fluids are hygroscopic, meaning they absorb water. Over time, water is absorbed and the fluid's boiling point drops. A typical glycol DOT 4 fluid that starts life at 450F dry boiling fresh from the can will degrade to 300F at 12 months by just picking up 3% of its weight in water. By 24 months its likely to be well below 300F at 5% water. In modern brake systems, most of the water absorption occurs in the plastic reservoir on the master cylinder. Poly-based plastics are slightly water permeable, so even brake fluid packaged in plastic bottles is subject to water absorption. Metal cans are superior, Ford Heavy Duty DOT 3 ("Preferred by Racers Everywhere...") is packaged in metal, as is Castrol SRF ($70 per liter!). If you're buying fluid in plastic, try to find a date code on the bottle, get the most recent batch if you can decode the numerical mess."
Emm
269
UK
The above is taken from the service stamp book from a 08 model year Seat.
On taking my car in for it's 2nd year 20,000 mile service, I was told by the dealer that:
"08 model year onward have the brake fluid change for the first time after 3 years, then every 2 years i.e. as per the book. Earlier vehicles are every 2 years."
Why the change in change periods I don't know.....
