180bhp leon Cupra chip
SeatR
399
Norway, Bergen
Hey, when chipping the cupra k03s, with forge DV, Fmic, catback, 4bar fpr and 3"maf
How many horsepower should i see ?
And how many with a k04-001 and 225 BAM injectors
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
depends on the map and what stage its mapped too, youll see around 10bhp less due to not having dp and cat, which usually allows stage 2 map, so based on stage 1 map witht hose mods, around 215bhp
ko4 hybrid should see 280-290 with the right supporting mods, which needs more than just bam injectors
jamiebennett81
k04-001 is a borg warner turbo = k03s
with those mods you will see around 220bhp max
the DP and cat are the restrictions here
and with a remap, on this turbo with the mods you have, you wont need 225 injectors, you will keep the standard ones
are you confusing the k04-001 with a proper K04 BAM engine turbo? if so, its not a direct bolt on. The mani needs changing and so does the charge pipe work to FMIC
SeatR
399
Norway, Bergen
no i know the differense on k04-001 and k04-015 and 23
What need to be done to reach 230 with k03s then ?
jamiebennett81
a sustained and true 230.....
with the mods you have, a turbo back exhaust and FMIC will be needed. that should see 230
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
bigger dp and sports cat should max it out to around 235-240. fmic is optional at getting these figures but youll need it come the summer temps.
not much more can be had off this turbo
SeatR
399
Norway, Bergen
ok! because im thinkin of buying a LC 180bhp 4x4! but it was far slower than my chipped ibiza :D
So need to sqweese out some more juice :D
jamiebennett81
technically no its not needed, but would be pretty silly to run this sort of power without one
it would drive like a diesel with power tailing off sharply at around 4500 due to heat soak from a few spirited bursts.
I would strongly advise anyone getting an FMIC if they have these kind of modifications and want to run this sort of power.....otherwise you are not getting the best from your setup
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
Ran mine at 242bhp for a year without the fmic. power held till 5.5kish (jabba mapping) and generally coped well as a daily driver.
But prolonged sprited driving in the summer would make a difference. The powerband stayed the same... just less power. So yes FMIC is a worthwhile purchase but i personally wouldnt say needed for stage 2 at the point of mapping, more a worthwhile add on.
jamiebennett81
daily driver yes, but if giving it some which we all do on a mapped car, it will soon start to pull back
personally if it was me, I like the optimum setup:)
SeatR
399
Norway, Bergen
Im getting a 3" Downpipe with race-cat!
Would i see any gains with fitting an exhaust mani as well?
Thinking of going k03 hybrid sometime next year, so are most likely to collect all the parts needed over time.
But would it be best to add Manifold before or after stage 2 remap?
