when i 1st joined someone said it fecks the handling up..... why? has anyone fitted 18s, i really want some.... thinking about golf r32 alloys and the smallest are 18's
With 18's your Speedo will no longer be accurate, due to the larger circumference of the Wheels (compared to 'standard' factory fitted 15 or 16's). Also the faster you drive, the more un-accurate the reading on the Speedo will become.
No big deal until you are cruising along the motorway *thinking* you are driving around 75mph, when infact it's around 85mph.... are those flashing Blue lights in my rear view mirror... or a Chav with OTT blue-neon windscreen washer jets![]()
Fitting larger Alloys, the Speedo will read your speed as being SLOWER than what the car is actually travelling at (as the Speedo would have been calibrated at the factory, with the standard 15 or 16 inch wheels fitted).
The larger the wheels are from standard, the more in-accurate the Speedo will become.
The only way to accurately test this, would be with the use of a Speed trap/gun, or using a GPS device.....
Cruise along at a steady 70mph (BY LOOKING AT YOUR SPEEDO), then look at the GPS device to see what your ACTUALLY doing
Afterwards, repeat this test once you have your shiny 18's fitted, and see what the speed difference between the Speedo and the GPS is then.
Will be an interesting test, please report back if anyone can try this!![]()
So you are a boy racer who wants the biggest size Alloys that will physically fit into the arches of your SEAT Ibiza.... who cares what the Speedo says or even if it's accurate, your probably too busy getting hypnotized by your neon washer jets![]()
ibizasport16v said:so wats everyone saying? go for it?
......that's right, and fitting 18's means the Speedo will be EVEN MORE unreliable than what it already is, so that's 'what I'm on about' too.![]()
