went and tried these on tonight:
http://www.edition38.com/forums/index.php?showtopic=211490&st=20&start=20
unfortunately they require either 25 or 35mm spacers to fit..and he only had the 35 handy. They looked sooo sick! but rubbing would be a big issue..i'm hoping for some dish but hopefully without largish spacers & 'safe' for 400hp.
Bigfellas car was awesome, i stripped some shiny engine stuff off it when it was written off, the rims were nice on that but ideally i want RS 003's...just need to find the right set
any more euro cupras out there with some dish?
10s will be too wide and wont be very good for handling on an Ibiza I wouldnt have thought. Even 9s might not be great for handling tbh. Would look nice though!
I think they would be possible with some smaller spacers(the wheels come with 25&35 out the box and wont fit without - it's the way they are designed) could prob get away with 15mm on the back if you can get them, sorry hoochno pics as it was cold and rainy, they stuck out of the arches alot but looked the dogs! I decided against because they will be at least as much if not more hassle than 003's and that's my ideal wheel
Like I said on the 35mm spacers they were too far out, the main tire tread stuck out of the arch by at least 10/15mm and that's not accounting for the tyre wall, the only possible way these could be run on an Ibiza is with 10/15mm spacers so u need to contact the wheel manufacturer to see if they do them, there is enough space between the shock and the back of the wheel to run smaller so if they do it is possible, I can't explain how good these look on a decked cupra
