150pd boost pressure
Slimshady
Hi, all, Ive got a 55 plate leon fr+ its running standard at the mo, Im about to order an oil pressure guage and a boost gauge (phantom's). I believe the standard boost pressure on a 150 is about 25psi, is this correct ? also Im thinking of gettting custom code to do a stage 1 job for me after christmas, what will this take the boost to ? will I be ok with a boost gauge that goes to 30psi or will I need a 35psi jobby to be on the safe side ? :think:
Merry Christmas :D
brad1
Standard boost pressure on a 150tdi is something around 16,17,18psi, mapped they go to around 22,23,24 psi.
Slimshady
Cheers fella, I knew that tdi boost pressures are way up on petrol ones, just couldnt remember by how much. Now I can order my guages. :funk:
verble fr
My Leon Fr tdi 150 spikes to 34psi the holds at 30 psi
Do you think this is too high? Remap, panel filter and exhaust are the mods
trebormint
333
Swindon
You'll end up with the turbo destroying itself via overspeeding the turbo. That boost is far too high for a standard PD150 turbo
