130PD Health Checking (+VAG COM)
EdButler
713
Sheffield
muddyboots said:
Do you know what sort of figures are claimed/expected from a DMS upgrade ?
172BHP and 280ft/lb - Not too shabby really. Cheers for the help muddy, just searched on Briskoda and your thoughts are confirmed - stock boost only!
Edit: It looks as though Faboka_VRS has a DMS or similar...?
Now ive gotta fine some pennies for a FMIC.... :blink:
muddyboots
Still hanging around
Oct 16, 2002
5,739
Not bad at all, especially considering no extra boost... :think:
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
Just had a go at logging some stuff, but i can't see blocks 3 and 7 (the ones i want) i logged intake temps and they rose to 90 degress v. quickly,
have i got an old version of VAG Com where i can't record boost or airmass???
where am i going wrong?
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
i logged GRQs car the other week , it has a star performance generic remap (same dongle as dms) and seemed to have stock boost ( clutch slip causes dodgy runs) , that car can shift , surprised me ,
at any1 reading this , wat is ur initial boost spike (actual) on a 130 map , im seeing 1.7bar falling back to 1.4 and holding this , is this correct , also seeing 2.0 bar spike with my remap on , defis go crazy when it happens , im thinking bad things at the min ,
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
Right ive figured out where to look to log module 3,7 and 11,
i will post up my findings ASAP,
Anyone know if bhp can be logged using Vagcom and is it accurate?
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
if ur ecu software is stock use block 20 to log torque , then post up the figures theres a sum u can do , il seach for it , need revs as well fella
EdButler
713
Sheffield
Stoney, im going for a drive to a mates tonight so ill switch off the 'go baby go' box get Mr. Mike to do some 130 logging for you...
maybe some of these infos should be made sticky? Theres Some good info appearing
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
cheers fella , that'd be good , looks my car is overboosting quite severely . but arent getting codes. confused ,
im working on a mk4 vagcom bit , any one with 150/180 logs 100/160 logs PM me
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
Right, Ive done a log off module 3,7 and 11, but how do i get them into a swanky graph?
can anyone help me?
also my vagcom only reads every second or so???
