This is actually a question for the Toledo 1.9 TDI but thought I would be more likely to get an answer here first.
Can anyone tell me what all the fuses are for on top of the battery, A diagram would be good if possible.
I bought the car two months back and have not used it as yet but while working on this and that I have noticed that one of the flat fuses must have blown in the past and has been replaced with a cut thin piece of mild steel
The wire from this (Whatever it supplies) has started to melt because of the what now is probably a 200A home made fuse, It has also started to melt the fusebox a bit![Furious    [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
I have done a search through the forum and thought I had found the problem when I read all the problems with the cooling fan fuse but from what I have read this fuse would be the blade fuse nearest the N/S wing, Is that correct ?.
The fuse that is the problem in my case is the flat one bolted in and from memory it is red with a white trace,.
I also need to know what amp this should be if possible and if anyone has any wiring info on what all these do then so much the better.
Can take a photo if needed, Thanks in advance.
Richard
Richard
