1.9 tdi AHF popping glow plug fuse
hardcore4
68
Hi Guys
Last year i got given a 1.9tdi leon to use as a work wagon. Its served me well apart from being sluggish to start in the mornings. I charged the battery last year and a strip fuse popped on top of the battery when i started the car afterwards, i thought nothing of it as everything worked fine.
As the weathers turned cold i wanted to get the cold starting sorted out, i checked the glow plugs and found no power getting to them and after some investigation found the 80amp strip fuse on top of the battery to be blown. I replaced the fuse switched the ignition on with temp switch unplugged and sure enough glow plugs work a treat.
The problem i am having is everytime i start the engine the 80amp fuse pops again straight away. I have checked the alternator output and its 14.3 volts which i wouldn't consider excessive.
Anyone got any ideas or had this problem before???
Cheers in advance :)
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
At a wild guess, one or more of the glow plugs are below spec, drawing too much current. This should be logged, and throw up a CEL. A read of the fault codes using VCDS may help.
hardcore4
68
Yeah I thought this too but no fault codes stored in engine or instrument cluster:wtf:
hardcore4
68
Anyone??
Can't see it being a dodgy glow plug as the fuse doesn't pop with ignition on, only when engine is started
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
From looking at the manuals and my previous posts, I think the glowplug fuse should be 50A not 80A.
Which postion is this 80A fuse in?
