1.8t evap canister
chris_200120vt
MR carbon fibre
Oct 4, 2008
2,711
YEADON, LEEDS
it is the black cannister behind the washer bottle , it's for the us market for there emissions so is not needed over here mine got ripped out long time ago
CupraSean
Mk3 Ibiza Cupra
Jul 21, 2010
937
West Midlands
does it have any advantage of ripping it out ? will it cause any EML issues, not that mine isnt on all the bloody time anyway lol :doh: just be nice to know if causes any unwanted problems.
chris_200120vt
MR carbon fibre
Oct 4, 2008
2,711
YEADON, LEEDS
cleans up engine bay a little removes pipe going to the t/b back to the tip
i have had to problems put a 330 ohms resistor in light will only come on once every few months , but it can be mapped out which is what i shall be doing when it goes to jbs
adulka
116
i know where it is, but i didnt knew his function
so u said chris, i can his without probleme remove, than there give resistor and it is ok?
chris_200120vt
MR carbon fibre
Oct 4, 2008
2,711
YEADON, LEEDS
there is 2 ways you can remove the canister and pipework but leave the electrical part plugged in you will not get a fault code but will have to put up with the ticking noise it makes
or
remove the lot and connect a 330 ohm resistor into the plug but will get a fault code now and again i carry my hand held scanner with me so clear it when it comes up
Malixx
Look at this: http ://seat-bg.com/viewtopic.php?t=12994
I can not post URLs so i put space between http and ://.. Correct the link in your browser and there you will find what you have to clean to prevent errors in the EVAP system.. It is in Bulgarian but there are pictures which i think are enough.. ;)
adulka
116
ok nice one :)
and i have now one question
have 1.8T AQX/AYP Suction Jet Pump or not?
adulka
116
i was looking for AQX/AYP motor diagram but i not found it
i looked at now on AWD engine diagram, becasue it looks like AQX/AYP and there isnt, so maybe there will not be :-D
