1.4 TSI CZEA performance clutch
Jan 5, 2023
Hello all , I recently made a mistake whilst being naive and bought a performance clutch for my car however the engine code was for a CZDA , I was under the impression that the CZEA was identical but has the active cylinder capability. However the clutch kit did not fit at all does anyone have any updated clutch kit recommendations for the CZEA engine thanks
Full details 2015 seat Leon MK3 SC 1.4tsi ACT CZEA sitting at 198bhp hence looking for a performance clutch as the stock one has started to show that's its on the way out
SuperV8
1,768
851
Sachs link clutch kit 3000951681 to the Leon CZEA -
6 speed manual. 230mm dia, Hub Profile 20,4x22,2-28N, Number of Teeth 28
Sachs have a performance range where they add -S to the part number.
Searching for 3000951681-S shows an performance version - they link to the Transporter!
Diameter [mm]: 230 - Number of Teeth: 28 - Hub Profile: 20,4x22,2-28N
Reinforced Clutch Kit, custom-modified.
Transmittable torque about 15% higher than the OE clutch kit.
Includes SACHS clutch cover, reinforced clutch disc with performance clutch friction material and SACHS release mechanism.
Manufacturer compare numbers
VW
03L 141 015 N
04E 141 015 K
03L 141 015 NX
02A 141 165 R
They don't mention the Leon with the -S version, but they do link the Transporter and the Leon with the standard part, and the the same VW OE numbers.
Luk are also linking the Leon CZEA and Transporter - which might help validate the link - or they have both copied incorrect data!
Reactions: West2729
Jan 5, 2023
VW
03L 141 015 N
04E 141 015 K
03L 141 015 NX
02A 141 165 R
Thanks! this is perfect ill start on my second round of research hopefully this time round its much less epencive and actually fits this time
absolute Hero .
Reactions: SuperV8
Mar 20, 2024
Bonjour je suis dans le meme cas seat leon 2018 czea 1.4 tsi 150
Je recherche un embrayage sachs mais je ne trouve pas la bonne références
Pouvez-vous m'aider ?
Mar 20, 2024
