1/4 mile results from today...
JayCee
236
Isle of Man
Well, as per my other thread about Revo settings, I had three 1/4 mile runs today.
Had the traction control off and was very nervous on the first run - couldn't believe it considering its not the first time I've done this! Ran a couple of 14 sec runs and when I went for the third I had crap reactions to the lights, but got the gear changes / traction much better and posted 13.29 at 103mph! Well pleased with that, much better than I had expected.
The three runs I had were against pretty random cars - Saxo VTS, Capri (!) and a 306GTi - beat all of them, obviously! (although they all beat me off the line....).
RobH
1,547
West Yorkshire
Was this at a proper drag strip with good accurate timing gear as that is a good time for a stage 1 car with no chassis mods???
JayCee
236
Isle of Man
Yup, Stage 1 Revo b8, t5, f9. It was at a disused airfield with the local Drag Club Association - proper timing lights, 0-60ft timings etc. I was surprised with that time, but also very happy!
The best 0-60ft time I had was a 2.410. I think my gear changes and pick was much better on that run than the first two and I floored it in third and fourth not worrying about whether I would have traction issues or not.
I saw some of the bikes there doing low 9s and terminal speeds of 145+! Much prefer four wheels..
Al
7,331
9
Pretty sure this will appear as being sour grapes/pessimistic or whatever, that that seems a pretty optimistic time given a rather slow 60 foot time and low top speed, but fair play.
As a comparison, the 2 sub 13 second cars (12.9) both did 60 feet in 2.2/2.1 seconds and topped out at 115/111 respectively. Based on this, had the 2.2 60 foot time been matched here rather than 2.4, 13.09 would have been on the cards @ just over 100mph with 60bhp less.
Was the car stripped at all?
R 20vt J
Ross Jamieson
Mar 29, 2007
791
Irvine, Scotland
Remember that was at crail al so not as good a surface probs.
That is a very good time! I thought high 13's were the limit for a stage 1 ar! My best with no chassis mods or stripped was 13.8 and i really couldnt see me beating that!
What happened the two times u got 14's? Thats like nearly a second of a difference!
Well done though
JayCee
236
Isle of Man
I had taken the spare wheel etc. out (didn't do the back seats, but was tempted!) and had ~1/2 a tank of fuel and me (75Kg ish).
I agree that the time does seem quick, but the timing seemed fine for everyone else so I have no evidence to prove or disprove it one way or another.
On the first two runs I can say that my gear changes and throttle application caused a far amount of "traction issues". LOL! Will have to try again next year (maybe with some other mods) and see what happens.
Al
7,331
9
Fair play.
The detail I was working from was the launch (60 foot time) being approx 0.25 seconds slower than the two 12.9 second cars - which brings you to the end of wheelspin territory. Thereafter, power and weight are king, and its clear there is a significant top speed disadvantage by the end.
The two 12.9 cars were working light wheels, light brakes, completely stripped, S2+ mods, LSD, next to no fuel, octane boosters, sticky tyres etc, one with a WOT box.
I guess I just find it hard to believe that a slow launch a slow top speed can equate to a near identical time, because the only place the gap could be closed would be mid range, and if you do the sums, its just not really possible - in other words, a heavier less powerful car with less traction (ie no diff) with a slower launch and 10% slower top speed doing similar times is just unlikely.
JayCee
236
Isle of Man
Yup, not going to argue with that. Unfortunately, I wasn't organised enough to have my own kit i.e. VCDS or GPS to back up or refute what I was getting from race control - still happy though!
Dec 2, 2008
571
Nottingham
well done.
Just goes to show what these cars are capable of. Even in standard form.
If you serious about doing more runs I'd recommend fitting a short shifter. The distance in the gate between each gear in the cupra is so huge.
I keep changing my mind each time I consider my next mod. Should I go more power or should I add stuff to make more use of the power I have. Always a dilema!
JayCee
236
Isle of Man
I'm thinking tbe first, then/and twintake or dbilas. This is of course after I have saved up for a while!
Short shift could be interesting...
