Replaced the water pump and timing belts but forgot to disconnect the battery. Coolant is low as I was unable to refill properly without the engine up to operating temp (stat open). Throttle body was removed for inspection.
Engine started up immediately and ran a couple of mins before the EPC lamp came on. Detected codes 17961 & 17604 using a code reader. Engine would not start. If I reset the codes engine will start and stop again with the EPC lamp and same codes. While the engine is running it will not idle at all and sounds rough at low rpm (have to keep revs up around 2000rpm to avoid stall). Engine was running OK before.
17961 - Barometric / Manifold Pressure Signals (something about implausible correlation)
Fault Location:
Manifold Absolute Pressure (MAP) Sensor (G71)/Barometric Pressure (BARO) Sensor (F96) - Range/Performance Problem
Possible Cause:
Intake/exhaust leak.
Exhaust Gas Recirculation (EGR) system.
Evaporative Emission (EVAP) Canister Purge Valve (N80).
Throttle control unit.
Wiring.
Manifold Absolute Pressure (MAP) Sensor (G71).
Barometric Pressure (BARO) Sensor (F96).
17606/P1198 - Oxygen (Lambda) Sensor Heater Circuit: B1 S2: Electrical Malfunction
Possible Causes
Failed O2 sensor heater circuit
Wiring Harness issue
Failing ECM
Any suggestions please as to how I can diagnose the cause?
Fault Location:
Possible Cause:
Wiring.
Possible Causes
Failing ECM
