1.2TDI P0405 fault error
costid
Hi all,
I have a 2011 Ibiza ST, 1.2TDI Ecomotive, and for some time I have the following fault engine code:
P0405 Exhaust Gas Recirc. Sensor-G98- (A) Circ Low Input
Did anyone had this problem before and how can I fix it? Which part do I need to change? :think:
Thanks in advance,
Costi
marijnensam
11
Hey, first you check the connector on the egr cooler. White grey connector. If it s stuck then go to the dealer for an software update. If the software is up to date already then replace the egr cooler. It's about 4 hours work. Dismounting the dpf, right drive shaft than you can reach for the cooler. Always mount new gasket and clamps! They are leaking with old ones! Hope I could help you
Verstuurd vanaf mijn SM-G900F met Tapatalk
Corvus Cornix
Newbie
Jun 30, 2005
47
Norway
My son's Ibiza got this problem a year ago, its not under warrenty, and here in Norway the fix is 1000£. He has not fixed the problem and got loss of power with revs under 2000.
On saturday I ordered a refurbished egr cooler part:03P131512C on ebay for 200, gonna arrive on thursday. the plan is to put it in this weekend.
Corvus Cornix
Newbie
Jun 30, 2005
47
Norway
The refurbished egr cooler is mountet today. 6h .
Still have the engine fault in dash and its still in limp mode under 3000rpm.
Gonna clear the fault with vcds tomorrow, hopefully it works.
Corvus Cornix
Newbie
Jun 30, 2005
47
Norway
Had to buy a new vag-cabel, the old one my wife hide. Did clear the faulty codes, then a new one appered:
14135 - Diesel Particle Filter; Differential Pressure Sensor
P2452 00 [191] - Elect. Malfunction
Orderd a new sensor, 30£
marijnensam
11
And when you mounting the new one, you have to adept it to the ecu for the new offset value of the g504 differential sensor. Otherwise it will give error again
Feb 4, 2019
Did you guys manage to fix this? I've had the exhaust gas temperature sensor replaced recently and then around 100 miles later I got the p0405 code. I've cleared it but seems to come back after two trips.
