012555 - Low Pressure Fuel regulation
May 25, 2008
1,919
S.Wales
www.seatcupra.net
hi guys need some help with this, I can read faults but not sure how to translate them..okay I was on a club drive today driving on the welsh roads around brecon beacon (good drive and weather :) ) I'll be honest I never actually drove my car this hard before switching gears rapidly and braking hard I do alot of motorway driving but not country club driving like this (first time) anyways back to the subject about half way after doing 150miles of driving or even 200 my car started to choke alittle I been using texco super ron (whatever they call it) been driving fine until now...
01-Engine -- Status: Malfunction 0010
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1P0 907 115 D HW: 1P0 907 115 D
Component: 2.0l R4/4V TFSI 0020
Revision: --H14--- Serial number: SEZ7Z0E3320055
Coding: 0303000318070160
Shop #: WSC 25038 576 94115
1 Fault Found
012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
P310B - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 3
Mileage: 102466 km
Time Indication: 0
Date: 2000.00.00
Time: 14:56:36
Freeze Frame:
RPM: 1668 /min
Load: 11.0 %
Speed: 24.0 km/h
Temperature: 86.0°C
Temperature: 51.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.097 V
Readiness: 0000 0000
Theres no ECU light on the dash and the car is driving fine (thankfully when this started we arrived at a break point so the cars and cool down and what not but err if i have to explain the car was in limp mode for the first time? I let the car idle for about 10mins and left it off for another 20mins but yea after the rest the car was fine again but I did a scan and came up with the fault code
im running stage2+ parts however I don't have a map just yet and the fuel pump is a autotech internals - so far so good but i thought I post it up
anything i need to look out for or will the remap correct it (remap will be done very soon stage2+ that is)
DanGB
Who need's a Diesel....
Feb 12, 2006
3,772
London
I get this error quite alot, but with no effects, never quite got to the bottom of it. It seems to be the low pressure side of fueling, so perhaps related to the intank pump.
May 25, 2008
1,919
S.Wales
www.seatcupra.net
odd then again im wondering if its because i have the part but no remap to control it correctly like fueling wise but then again i have never driven the car this hard alot felt like a snakey track yet not breaking speed limit its okay right now though...I haven't erased the log yet just saved the error
thanks dan
Cuprarob112
403
Got this fault a few times. In the end it proved to be the the low pressure (intank) pump. Fact is is doesn't break down but after some time starts to wear out an give less fuel. Installed a new one together with a Audi S4 fuel filter and all was fine again.
