There seems to be quite a bit of interest on fitting heated washer jets at the moment, so thought I'd see what info is around with regards to fitting.
First off, I've found a wiring diagram which shows how the factory-fitted washer jets are wired up.
It's on page 17 of 32 here (index is in Spanish, but look for "Surtidores lavaparabrisas calefactados"
Z20 and Z21 are the heated jets and T2o/T2n are the connectors on them.
D/15 I think is the ignition switch (D is anyway).
Anyone know how to interpret the rest of the diagram ?
Specifically these numbers:
B135
C14
167
Also - the location of these connectors:
T2e (2 wire connector)
T6b (6 wire connector)
If I could find out where these 2 connectors are I should be able to work out where to connect the heated jet loom up.
B135
C14
167
