Limp mode, dianogstic light on, help please.
Russ_20vt
Kitesurfing nut
Feb 4, 2005
468
T,Wells. Kent.
Hi Guys
Well today (christmas day) i woke up at 6 to start my drive down to conwall from kent to see the family. It was raining and horrible salty roads, about 30mins into the journey i notice my cars not boosting to its normal 14ish psi and only hitting 5psi dead on. So its gone into limp mode, i pull over and swith off and restart. Limp mode is still there. About another 15mins into the drive my diagnostic light comes on, now i pull right over and check everything out. Car was running fine but just in limp mode, a little bit later i go to pass a car and ive got all my boost back!but the light is still on.
Now the cars running fine but the lights still on. I thought it may need a reset so i disconnected the battery and diagnostic light went off. I went for a drive and im only hitting 10-12psi.
Im thinking dead MAF, any ideas? had a go at unplugging the maf but i cant see how the bugger comes off?
Now at my familys and have 300 miles to get home again.
Merry christmas everyone
Russell
Russ_20vt
Kitesurfing nut
Feb 4, 2005
468
T,Wells. Kent.
Cheers thanks Bill, trying not to sound blonde but im having a nightmare trying to get the Maf connection off so i can go for a drive with it dissconnected.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Its fiddly.. a small flat blade screwdriver will help to pop out the little catch at the top.. gently prise is outward and upward and it should release (with a wiggle)
some of them are really tight so and so's tho.
good luck
Russ_20vt
Kitesurfing nut
Feb 4, 2005
468
T,Wells. Kent.
Update, cleaned maf and went for a drive and no change.
Dissconected maf (tcs light came on) and went for a drive and no change.
Still only reaching 10psi max.
Any thoughts guys.
Russ
Russ_20vt
Kitesurfing nut
Feb 4, 2005
468
T,Wells. Kent.
Thinking could the reason i had no change when dissconecting the maf be because i disconnected the battery so in sense it has never had a good maf reading to divert back to?
Russ
