Last night, whilst driving home from work, a loud beeping woke me from the evening rush-hour tedium. I noticed the engine tempertaure gauge was reading >110 and the light was flashing. Luckily I was very near a service area, which I coasted into, and switched the engine off as soon as I could. The temperature slowly cooled as I was coasting into the service area and went back down to normal after leaving the engine off for a while. I checked the coolant level and under the car for leaks. No leaks / normal coolant level.
I then drove home through town, generally 30mph with a few stops and starts. Didn't overheat. I tested it last night by letting it idle - temperature remained normal. Took it for a little test drive slowly around the streets - no overheating. Drove it to work this morning (generally country roads / small stretch of dual carriageway but no motorways), no overheating.
After talking to a few people and searching a few threads on here, it looks like its one of the following problems:
Dodgy thermostat
blockage in the cooling system
broken water pump impeller
dodgy gauge
- someone also mentioned a damaged head-gasket
Vote now!!! (unless you have any better ideas!)
I could do with having an idea of what it could be before putting myself at the mercy of the dealership. Any suggestions will be gratefully accepted - I am a bit scared of driving any distance on the motorway just in case it happens again.....
Dodgy thermostat
dodgy gauge
