Phillips1795
VCDS - How To Guides - MK3 Leon 5F
aaroe
Hi,
Great guide, hoping to get some of these mods done to my car soon :)
What is meant by the "Air blower"?
Phillips1795
171
Corby - Northamptonshire
Air blower is auto mode on the air con. When this is adaptation is done and the auto button is pressed it illuminates the lights on all the controls so you know what the auto button is doing. Rather than just illuminating the single auto button light.
dephead2004
918
12
Hey guys this looks great. Thanks for posting.
Are you saying that if we have fog lights then we can easily switch on cornering? The motor must be enclosed within the fog light assembly.
Phillips1795
171
In theory yes but we found that if we activated the cornering. Lights they just stayed on all the time when you had normal beam on.
We didn't have time explore where we went wrong or what went wrong.
dephead2004
918
12
I understand. Surprised if they'd put motors in on the off chance of some being activated.
ac2013
49
There are no motors . I had mine apart to change the bulb.
The normal fog beam lights up the corners the same as when the cornering lights are enabled.
All cornering does is switch on the fog briefly when turning the wheel or indicating under 20mph.
fortunately mine were already enabled when I took delivery of the car. (SE version).
dephead2004
918
12
Ah that's interesting . Thanks. I have a BMW with cornering function and the lights are motor driven so I wrongly assumed that that is what the LEON had too.
Appreciate you clearing that up.
AJ
250
Great thread Kev & Zach, thanks for your hard work and providing us with great guides! Is it possible to tell me where I can get access to the Diagnostic Port please? Cheers!
johannesr
Cheers for the great instructions! Do these apply to any other models? I have Altea XL 2008 pre-facelift.
Phillips1795
171
They would probably be far simpler on earlier models as you do most of the changes in adaptations rather than long coding. But a lot of the above seem to only be on very recent models, lap timer etc.....
Tony_fin
21
Finland
Have anyone got Security Access code to ABS side? I would like to adjust XDS to strong but I´m missing access code...
Ckpearce91
1,287
15
Milton Keynes
Do you have the tech pack? Because my SE with tech doesn't have cornering function
ma9mwah
201
Double check you selected the correct options, the option names are very very similar. There's been at least 2-3 people who have done this.
