had running issues for a while now
have my own scanner and vcds free version & the only fault i get is glow plug and wheel speed sensor
but had my car compression tested and a proper vcds scan done and here are the results
17055 -cylinder 1 glow plug circuit (q10) P0671 -35-00 - Electrical fault
18072- control circuit for PD injectors P1664 - 35 - 00 Electrical Malfunction
00283 - ABS wheel speed sensor;front left (G47) 008 - implausible signal - intermittent
00283 - ABS wheel speed sensor;front left (G47) 012 - Electrical fault in circuit - intermittent
01314 - Engine control module - 013 Check dtc memory - intermittent
is this just a wheel speed sensor gone or the contacts on the hub ?? but why throw the two codes up ??
any help on any of it is much appreciated , car smokes when hot at idle , blue ish grey does not smoke at all under load or WOT and to avoid choking poeple at traffic i have to give the throttle a quick blip to stop it for a short period
also does not fire straight away need to hodl key on to wind it up
cheers
andrew
cheers
andrew
