Weight reduction summery thread
POPOV
Newbie
Jun 25, 2005
581
Sweden
This is a summery thread of various OEM parts from the Seat Leon Mk2 and their weight.
Great information for you whom want to change your cars power to weight ratio. Easy way of making your car go faster.
As individuals we all prioritize differently in life, some of us want performance and others comfort. So let's not make this to a thread about loosing body weight and personal arguments.
I will start of with some weights of various items and add as i remove parts or change. Hopefully others will contribute with more measures.
Orion Leon Cupra 18" alloy including 225/40/18 tire with 7mm left
21,4 Kg
Exide 12V Battery
19,2 Kg
Al
7,331
9
Uprated Brakes and single mass flywheel are weight savers as is air con pump and air con core delete.
Back seats, spare wheel, jack, screen wash, fuel, rear window wiper motor, all the unneeded crap inside the car like De Icer, CD's etc. Mud flaps lighter clothes, driver losing weight, carbon bonnet and panels, sound deadening under the carpet, front fog lights, catalytic converter. Could probs think of more if I wasn't pissed :)
POPOV
Newbie
Jun 25, 2005
581
Sweden
Intercooler excluding silicone pipipng
2,9 Kg
Spare wheel excluding tool insert and tools
14,5 Kg
Back seat upper part, including both sides as they can be split
17,9 Kg (11,9 + 6)
Back seat lower part
5 Kg
Trunk cover
2,5
Apr 13, 2011
1,971
hull
It's a good thread is this pitty it's for the Leon lol I was palning a stage 1 waight reduction on my mk4 Cupra.
And hears what I plan of doin but keeping it as oem and daily useable as possible
Ok
spere wheel toolkit and jack remove
Rear head rests remove
Inside grab handles swaped for blanking covers
Rear wiper and motor removed
Verious chassis bolts and engine bay bolts cut down due to longer than needed
Front and rear crash bar 35mm holes cut through out the bar ( still strong with holes)
And finally under bonnet frameing cut down and removed and cover refitted so still looks good ( lighter bonnet due to iTs one hevey lump)
Light waight battery
And possible aircon removal that should lose about 100kg well I'd like to think
Adman77
Audre Est Facre
Feb 13, 2012
774
Hertfordshire
Hahaha! That's what you get for speaking before thinking!
And I've already posted on this thread so I've already read that!! Lol
Mandu
46
Finland
www.youtube.com
Want to lose some weight before trackdays. I dont know is this right topic to ask but how can I remove back seats of Leon Cupra mk2? Is there one bolt in trunk, under that little plastic cover? Where is more. I try before find bolts, but cant find them. So please help. Thanks!
POPOV
Newbie
Jun 25, 2005
581
Sweden
Yes, remove that bolt and slide out the rear seats. That should be it if my memory is right.
Mandu
46
Finland
www.youtube.com
Ok, thank you. Thats about back rest, what about that what is under butt? I try to force it to lift up, but it only came to 45degrees angle. Should I force it more to see the bolts which it is attached?
POPOV
Newbie
Jun 25, 2005
581
Sweden
Just pull it harder and it will release, it's not fixed with ant bolts
otomobilsever
Advans feels much much better than the Cupra alloys: 7.5kg vs 13-14kg
