Had my mk1 unmapped LCR on the rollers at the weekend. As you can see from the printouts below my car made 176bhp at the wheels (this dyno doesn't give flywheel figures). The operator (who I'm told is very good) said this sort of output is about right for an unmapped LCR225, reckons they lose about 60bhp in the drivetrain. This seems a bit much to me (but I'm no expert) and Willie reckoned in another thread that this was a bit low too.
Drka-drka's car is mapped (or the seller told him it was) and he made 202 at the wheels which Willie reckons is a healthy figure for an unmapped car, so if that's correct then there's something wrong with mine. I had it logged by djhorace just after I got it when it was still 100% standard and it showed about 181g/s which works out about 226 or 231bhp depending on whether you multiply by 1.25 or 1.275 so I figured back then that it was probably in good nick for a standard car. Since then I've done the mods in my sig and the car certainly doesn't feel any worse, if anything slightly better for the mods. Fuel is always Shell V-Power.
Last thing is this - the operator said that on the Air Fuel Ratio graph that it should get slightly richer towards the right hand side and on drka-drka's car that was right enough. On mine it didn't and also the injector duty on mine doesn't go above 76%. He said this could indicate a potential fuelling issue, in his opinion likely to be caused by a MAF failing. Any opinions on this? Happy enough to get a new one but wanted to get opinions before I go spending the money?
Anyway here's my graphs, if anyone's got any other insight then I'm up for hearing about it
