intake Flow rate survey!!
vRSy
Fabia vRS
Jan 8, 2009
1,470
London
if any of you guys with ITG intakes have logged your cars could you please post up your intake mass air flow readings. *
Im trying to get a base comparison to see what they can achieve.
TFSI_mike===stage 2+ APR===k04 ===248g/s
gazbutS3=== stage 2+ REVO===k04 ITG===255g/s
vRSy===stage 1 shark performance===k03stock intake===200g/s
cupra_k1===stage 2+ REVO===k04 ITG===261g/s
vRSCarl===stage 2+ REVO===k03 Evoms===234g/s
KRL===Stage 1 REVO===K04 Twintake===249g/s
in fact i other guys could post uo your intake air mass in the above style with diferent intakes to get an idea what they are flowing. *(obviously all cars run differently but they should all be i the same regionish, for similar specced cars i the same regionish, for similar specced cars
vRSy
Fabia vRS
Jan 8, 2009
1,470
London
USERNAME===STAGE/TUNER===TURBO AND INTAKE===G/S
TFSI_mike===stage 2+ APR===k04 ITG ===248g/s
DJhorice===stage 2+ revo===k04 Evoms===275g/s
RodneyA
FR crazy
Nov 14, 2008
102
South Africa
how the heck do you guys flow so much,even on the KO3?!...i'm flowing +-175g/s with Evoms.
although i am 1400m above sea level..does that count? :)
vRSy
Fabia vRS
Jan 8, 2009
1,470
London
hot air is less dense than cold air, therefore for every degree cooler the air is, the more mass of air that can be flowed through the intake.
vRSy
Fabia vRS
Jan 8, 2009
1,470
London
K04 Cars
TFSI_mike===stage 2+ APR===ITG===248g/s
gazbutS3=== stage 2+ REVO===ITG===255g/s
cupra_k1===stage 2+ REVO===ITG===261g/s
KRL===Stage 1 REVO===Twintake===249g/s
DJhorice===stage 2+ revo===Evoms===275g/s
Hedge===Stage 3 Superchips===stock intake===259g/s
DomT===Revo Stage 2+/Stage 2 DSG===Evoms===277g/s
PDT===Revo stg2+===Dbils intake with open cone inplace of airbox===256g/s
GTiJames== Revo Stage 2+ == ITG == 251.1g/s
K03 Cars
vRSCarl===stage 2+ REVO===Evoms===234g/s
vRSy===stage 1 shark performance===stock intake===200g/s
muckipup===stage 2+ shark performance test map===ITG===204g/s
RedRobin===Revo stage 2===Forge Twintake===???g/s [to be added]
any guys with twintakes and k03turbos care to add. doesnt even have to be an intake.. could be a mapped car with std airbox
vRSy
Fabia vRS
Jan 8, 2009
1,470
London
what kit is required to measure flow rates, i'd be interested to do mine
lap top and VCDS lead. definately a good purchase especially with REVO as you can log your car and play with your settings throughout the different seasons to optimise your car once you get the hang of your logging(which is pretty easy now i think), becuase your logs will show you all the adjustments and if they are safe and within limits
http://www.goapr.com/support/datalogging.php
yazmidani
107
Lytham St. Annes
hmm I wonder if mine is broke...(MAF Sensor)
dave.c===Revo stage 2+ B9-T6-F5===Forge Twintake===180g/s (ko3)... haven't cleaned the MAF yet.
Well I've just done a quick run. . .
yazmidani===Stage 1 map===K & N Typhoon===191 (Ko3)
it does seem low compared to other results. . .should I be checking anything? Any other FR's got some results?:shrug:
Poverty
K04 Cars
K1 --- STOCK -----NEUSPEED ------187 g/s -----10 degrees ambient outside temp
K03 Cars
Poverty
So around 240hp going by your maf reading has it been on a dyno?
K1Shane
336bhp 319 lb/ft
Apr 17, 2010
730
Northfleet
K04 Cars
K03 Cars
Lol and I was just about to add this myself! Can anyone tell me if the highlighted log is normal. We are currently in the middle of working out if the car is mapped or not??
May 25, 2008
1,919
S.Wales
www.seatcupra.net
Nope not had chance to put the car on dyno yet...But yea it seems to run fine but always wondered if the MAF was reading the correct amount or if the data is accurate. When I get the chance I'll book it in with Revo HQ and let them check it all. (me thinks) pretty much have everything bolted on for the ko3 turbo about time I go ko4 soon :happy:
Poverty
Shane you maf reading suggests a power of 240hp, djhorace/al's maf reading would suggest a power of 340bhp for comparison.
Dave heard nothing but good things about revo hq especially regarding ben, I want to get down there at some point aswell!
Al
7,331
9
My standard FL LC has 201g/s with standard intake. Will log my car today Jason/Shane
