brad1
Evening all
Was out tonight and driving home i started getting a knocking noise and could feel it through the floor aswell, like a thud. It goes with the rythym of the speed, the quicker i go, the quicker it knocks/thud. If i push the clutch in and coast, the noise dissapears. I started getting the grinding noise too. The grinding noise is the same as when you have no pads left on the back disks and they grind. Especially if i go round a round about or turn right, it like grinds. Also i put the steering on full lock towards the drivers side and got under the car. I pulled the passenger driveshaft and it had a bit of play back and forth, did this to the driver side driveshaft with it on full passenger side lock and the driveshaft had no play in it. Does this mean my driveshaft is on the way out??? Please help
