moving battery to boot.
cus
... Vag only!
Feb 8, 2004
1,713
Middlesbrough
www.nemm.co.uk
hey people
daft question. i'm just sorting out moving the batttery to the boot.
i know about the power cable etc..
but the original ground cable.. can this be cut off, or does it have to still be grounded?
as the battery will have it sown ground cable in the boot...
cheers
cus
... Vag only!
Feb 8, 2004
1,713
Middlesbrough
www.nemm.co.uk
well i have one little problem..
my car proper struggles to start up, but does start eventually!
and when doing this, the radio resets itself.
is this due to cables being too thin? bad earthing?
once its going, it feels okay to drive./
The MoffMeister
Half Hoff, Half Moff.
Apr 4, 2006
2,937
colchester
the battery relocation wont cause this problem cus its something else along the lines my car is all fine now i sorted it out properly, just make sure your earth is good, take a earth from battery onto the spare wheel hole, rub down the patch and connect wel you should have no probs
could be a loose permanent live check connections
dai cupra
is it really worth it lads wot are u benifiting from this apart from more room in engine bay;)
The MoffMeister
Apr 4, 2006
2,937
colchester
more weight at the rear balancing the car more, and making the front lighter, more room for extra bits and pieces like oil catch cans, bigger air filter cones etc
dai cupra
good thinking lol might consider doin this wot cables do i use or as any one got a guide so i can follow many thanks moff
kyle'87
Modding Disease
Sep 15, 2008
868
Ruislip
Thought I would bring this thread back up as I am looking to do this but got a few questions...
I plan stick the battery in the boot however just want to clear few things up.
I will need to extend the ground to the boot which will be straight forward
The power cable again can be extended to the boot however want i want to know is the black fused 'dizzy block' on the battery, can i replace this with a proper fused dizzy block and then run that one cable to the boot? so have just three cables going to the boot and get rid of the crappy black dizzy block?
Nov 2, 2004
9,335
South Wales
Extend the ground to tyhe boot? You got a negatibe terminal on your battery mate, short piece of cable to a good clean point in your boot will do. :D
Only need one cable to the boot.
Your making this way too complicated.
Easiest way is to run one cable from the battery direct to the starter motor and earth the battery in the boot. Thats it.
kyle'87
Modding Disease
Sep 15, 2008
868
Ruislip
ok cheers mate, though I was making it bit complicated lol
or look on the guide and read!!
I searched and can't find it :(
Searched in the LCR section and still couldnt find the answer I needed
