ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
Just thought i would put up some info on my car and some pics and try keep it updated when i do more things to see what you all think. Heres the car as it stands and what else i want to do.
Engine:
AM04 stage 2 turbo with Eurospec sports actuator
Greentop 440cc injectors
THS high flow performance manifold
Blueflame / Pipewerx turbo back exhaust system
LCR MAF Housing
Forge 007P dump valve with yellow motorsport spring
VR6/G60 Clutch & Flywheel setup
NGK spark plugs
Bolt down coil packs
Bailey alloy header tank
Jetex induction kit
Removed N249 & N112 valve
SAI removed with Forge blanking plate
Forge/SFS vacuum hoses
LCR Forge turbo intake pipe
Jabbasport custom map
AM FMIC with 2.5" alloy pipework
Oil catcher tank
Inxx bonnet lifters
Braided fuel lines
3" Cold air feed
Black rocker cover
TT Short shifter
Suspension:
FK Highsports
Seat Sport/MOMO front strut brace (Gloss black)
Polished rear strut brace
15mm rear Eibach spacers
10mm front H&R spacers
Interior:
Autometer Oil Temp gauge
Autometer Boost gauge
Nomad dual A pillar mount
Short shifter with Richbrook slant top gear knob
Exterior & Lights:
Pressed plates with Seat plate surrounds
Colour coded brake calipers
De badged
Leon Cupra R front spiltter
Aero wipers
Rear wiper removed
Gloss black inserts
Gloss black wing mirrors and baseplates
Stubby driver's wing mirror
Black rear 'S' badge
Black front grille 'S' badge
Stubby aerial
6000K HIDs
Phillips Bluevision sidelights
Silvatec indicator bulbs
Alloys & Brakes:
Brembo 4 pots
Ferrodo DS2500 Pads
Elliptical Groved disc's
Braided hoses
Motul RBF600 Racing fluid
17" Team Dynamics Monza's with yellow pin stripe
ICE:
Infinity Reference 5760A Amp
JBL 1000W 12" Sub
6 CD Changer
Things to do soon:
Few small things
Bodywork
ARBs
Tints
Then just general tidy up :D
Let me know what you think, and i will try keep it upto date!
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
Bit of and update for you said would try keep it upto date
I bought a few new parts for its recently
If you cant tell from pics iv got FK coilovers, Brembo brakes, AM cooler with pipe work and Bailey coolant bottle.
I fitted the cooler today took ages as wanted to get it right some pics on when fitting i havent got a fitted one yet as went too dark to take good one
My manifold is still blowing so not felt full benefits yet but it defo is miles better with new cooler than old one on there anyway
So next on list is to try some how to stop the manifold from blowing, but think im going to have to take that to a garage to get done as i cant get to the nut. But will be fitting brakes and suspension this week hopefully
Let us know what you think of the upgrades :)
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
Sound i seen the pipe work looks very good quality, why is your turbo called a am04 just out of interest , is it a ko3 or ko3s hybrid and do you know who did the turbo ?
yea pipe work it top notch really light all smooth bends in it and fits spot on.
basically the AM04 is a unsilenced k03s hybrid (k04 internals, porting, balancing, interchangable bearing cartridge, larger impellor wheel, larger enterance etc etc) and tis called a am04 as the company that made it where called AM motorsport.
arron2004
Cupra Boy
Mar 1, 2007
903
Nottingham J25 M1
Spot on thats answered every thing spot on thanks chris why do ppl have them silenced ? are AM motorsport around had a look on net and cant seem to find em
jamiebennett81
Chris check out my build thread for issues with the mani and bolts....
when you fit yours, make sure the bolts are long enough for the thread to go through the nuts and actually lock
I strongly suggest buying one of these as well to further lock the bolts and nuts in place...
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
Just came silenced and unsilenced bit louder when no silencer obviously. AM not around no more mate so wont find them
