What Boost
Millsy87
Hey im just curious what boost people are running and how the boost is delivered, as in between what rev range etc.
Im running pretty much standard with only revo stg1 and forge dv, and am curious to see what other people are seeing??
Millsy87
I have im trying to compare, to make sure mine is ok. it seems to be the same as yours, spikes to about 20 holds for a while. does yours hold boost all the way through to the redline, or drop off before?
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Is yours a k03? if it then the ko3 doesnt hold boost for longer than 3000krpm...tails off at 5.5krpm...
K03s is a different story holds boost for longer up the Rpm range
Mine hasnt been Mapped yet just doin my FMIC and other bits be4 hand..
Millsy87
Yer Only KO3 thought this was the case, i did see somewhere people holding up to 26psi, or is this only with a Ko3 etc?
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
Mine peaks at 1.6BAR (23psi), holds at around 1BAR (14.5psi) but tails off quite quick. (ko3 on REVO1 by the way)
