right been out and had a look, its raining and i cant figure it out from the pic so heres my edited pic if you could
help
Ok....
from your picture...And i hope you understand this as I do not have a program to add arrows etc. So take your time to read what I wrote and maybe even print it out to take to the car...It will
help trust me!
so:
The furthers questionmark on the right on top of the dump valve (the silver thing...you might still have original black bosch but it will still have a small nossle with hose from it) that goes to
T piece found just under the black and white small filter (looks like checker piece).
Then the questionmark on the left goes to the hose where you put the second questionmark on the right. There will also be another T piece as this again splits into 3 seperate wires.
This wiring has nothing to do with the Bypass and will not change but it is better to change all original tubing.
Then the red line you drew under the oil cap goes to a small nossle under the 4 intake pipes? (i am not native english speaker so not sure what they are called...but I am talking about the 4 silver metal pipes showing at far bottom of the diagram)
Take note here...there are 2 nossles there...so follow the tube that comes from the small UFO like silver/copper object that you see on the right bottom corner of the picture....where that tube goes is NOT where the red line tube goes.
This should be enough info.....like I said read it carefully and just take your time
Good luck and if you need more
help then eddit another picture with coloring
