wrong oil in my PD 150????
barryg
151
Dublin Ireland
www.barrygraham.ie
While browsing the site I see the recomended oil for pd engines is vw 505 01 .. problem is I have vw 505 00 in. (thats what i get for listening to the guy in the auto factors)[:@] . I only changed it 2 weeks ago, but the oil used on the previous change was the same... im just wondering am i doing dammage by using the vw 505 00, what is the difference between 505 00 and 505 01??
should i take it out ??
mrcoyote
See no evil...
Jul 26, 2004
2,624
Definately. There's the chance of increased wear on the cam lobes, etc with the wrong type of oil. Check the TDI sections stickies for more detailed reasons...
craig-pd130
353
Manchester
You absolutely 100% need 505.01.
This spec oil has a special anti-scuffing additive for additional protection of the camshaft lobes which actuate the valves and injectors.
These operate under such extreme loadings that the oil film can be broken down by the pressure, allowing metal / metal contact.
The additive helps prevent this.
Get the guy to change to 505.01 / 506.01 (long life) right away. He's wrong, end of story.
It's impossible to say without removing the cam cover if any damage has already been done to the cam lobes or followers, I'm afraid.
Fingers crossed it's OK for you.
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
Yes - Go down the auto factors and give the bloke a slap. If you're lucky, they'll be a Millers oil stockist. If so, get a 5 litre pot of Millers XFE-PD which is 505.01 compliant and get it in your car asap. I doubt there is "serious" damage being done by running on 505.00, but it's not ideal and should be changed.
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
Millers XFE-PD should be about £25 for a 5 litre pot. This is a bargain compared to what the dealers charge. ;) And I think the PDs need good oil for some reason - Might be to do with the charge pressures in the injectors, and the camshaft, etc that makes them work.
barryg
151
Dublin Ireland
www.barrygraham.ie
halfords have a 5L can with vw spec 505 01 oil.
anybody use or is it muck?? if it has the vw spec it must be ok??? its only 39.99 euro castrol is 49.99 for 4l and 19.99 for the extra 1l needed
Viking
Insurance co's are crap.
May 19, 2007
2,317
Near Richmond, North Yorks
Fuchs Titan Supersyn VW 505.01 - 5w 40 weight oil is on special offer at my suppliers, costs £54 for 2 x 4ltr cartons, with free delivery. It'll cost you a little bit more than that though unless you can get membership for their discount scheme.
Ah, just seen that you're in Dublin, so delivery may be an issue.
muddyboots
Still hanging around
Oct 16, 2002
5,739
Hmm, what with various posts recently about severe cam/tappet wear on PD150s that have been fully serviced with the correct oil, I'd be a bit concerned if you've been running on the wrong oil for that many miles.
