Car not starting and not idling well - possible causes?
Hicks
Let's nuke 'em from orbit
Nov 26, 2002
420
Relocated Yorkshireman
Cupra 1.8T. Car sometimes doesn't start, usually when it's been standing for an hour. I don't think it's the battery as it's turning over ok, just no ignition. Looking for any suggestions on what could be causing this?
Also, I don't know if this is related, but the engine is sometimes very hesitant at idling and low revs, and I get no power. It does pick up after a minute though. I found the thread talking about split hoses, so that's something to check.
It's just had a major service, including plug changes, but I'm still having problems. Any ideas, especially on the starting problems?
Thanks.
sebasti0n
81
Had the same on mine mate.... changed the Temperature coolant sensor.... all well now.... I had one of the OLD Black sensors.... replacement one is green.
£26 from stealers..... easy to fit by yourself.....
Cupra2505
Andrew,
I've got a similar problem, although mine starts with no problems. Outside of this forum a VW technician has suggested the Temperature Coolant Sensor as well. I'm picking it up tomorrow and plan to fit it over the weekend. I'll let you know how I get on next week.
Mark
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
its on the right hand side (under a cover) viewing engine stood in front.
its held simply by a C clip affair (plastic) in a plastic junction. 4xwires out of the top of it in a coolant line. Pull the circlip out, pull out the sensor, insert new one, refit circlip, replug electrical connector, easy peasy.. do it on a cold engine however. some water will spill out, but not much if you have the new one handy and ready
easy DIY
Cupra2505
Andrew,
Hope it works out for you. I fitted my Saturday afternoon with some high hopes of improvement. Well I'm 80% there, it's still not quite how I want it to be - but maybe I'll just have to live with it.
