Total Closure System (Remote Windows)
mds1256
Facelift Leon Cupra
Jan 7, 2007
1,012
i know this question has been asked before, but no deffinate answer. just wondering can the MK4 ibiza have remote windows like the leon. I have vag com if this helps. I email the supplier of KWP and they said the MK4 wont work with this module and can be done via vag com???
any ideas
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
im not sure if it can be done on the remotebut if you stick the key in the drivers door external handle and twist it
left and hold it the car will lock and windows will go up
and
right and hold it the car will unlock and all the windows will go down:)
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
yes it can be done, just buy a little plug it chip, it plugs into your diagnostic plug and has a one time use and enables total closure
it's about 28 quid
there is a thread on it, I'll see if I can find it for ya
cobain
funnily enough i did this to my ibiza last week! i have got a mk4 03 plate se tdi.......... got my kvw100 from http://www.vagproducts.co.uk/ real speedy delivery, £25.99 inc P+P, just as it says plug it into obdII leave for the 3 beeps and hey presto! is brilliant! [B)] cant quite work out how it worked, but it did! :D
rashcupra
Oct 15, 2006
6,517
crawley
what so you just buy this plug in chip and it sets your vehicle to close the windows if left opened when its locked with the remote!?
rashcupra
Oct 15, 2006
6,517
crawley
do you have toleave it plugged in all the time or does it adjust ecu accordingly? then you remove?
Nath.
Jan 1, 2006
8,619
16
reading the thread it just plugs in beeps 3 times to confirm upload then remove it and throw it away as it is a 1 time use
but gotta be worth 25.99 for the crack of zapping your windows up and down :D
I have spent 25.99 on a a lot less in fancy restaurants :(
cobain
its all in the instructions but basically turn the ignition on, plug it into obdII (practically under steering wheel.....spent hours looking! :rolleyes: ) when you plug it in it beeps then about 45 secs later 3 beeps and then remove it :clap:
mds1256
Facelift Leon Cupra
Jan 7, 2007
1,012
a see
so how do u work it on the ibizas
hold the lock button to shut the windows and hold the open to open the windows.
Also i have heard that this can foul the alarm up?
Let me know your progress when it arrives
cobain
hold open to open all windows (they keep opening till you let go or untill open) and a single press to lock doors and windows close up as you walk away!:D
