The wife picked me up from work tonight and i found my biteing point had changed alot and there was a large amount of play in the pedal. Made it home and guess what..........the second i pulled on to my drive it snapped.
Its the common crap welds that have given way.
I read on here that steering column has too be removed........this is rubbish. I have removed mine with a phillips and flat screw driver.
Here's how.
Remove the plastic panel in underneath by removing 3 phillips screws. Remove that compartment under steering wheel.
Now remove the clutch pedal switch by screwing it out.
Remove the safety clip on the end of the pedal axle with the flat screw driver and remove the clip on the other end of axle (next too brake pedal.
Slide the axle along too the drivers side until the clutch pedal can be wiggled out of place.
Becareful not too get hit in th face by the over centre spring.
Here is what ELSA says with diagrams.
Weld it up and refit simple.
Right iam off too weld mine up now.
Hope this is of some help to someone.
Matt
Here's how.
Matt
