The other week I went into SEAT to get the car looked at as I had an error code coming up on the dash. They fitted a new MAF as they said it was logging error codes.
I cleaned the air filter the same day, and after all this work had been carried out I noticed a slight whistling noise from the engine bay on full acceleration.
I hunted for an air leak and couldn't find anything.
Anyway I set the car back to OE map and took it back to the dealers. They have taken it out for a test drive and said that they are seeing spikes of 27psi, and the whistling sounds like the turbo / wastegate may be knackered and thats why I'm seeing this level of overboost.
Does this sound feasible, and if so I take it it's going to be expensive?
