What silicone pipe do i need??
itfben
DsignVinyl.com
Oct 24, 2009
2,000
nr. Tunbridge Wells
would 1m be enough or should I go two, I want to do all my vaccumm hosing in my engine bay like everything that can be dont really! so looking at...
1m x 4mm
1m x 8mm
1m x 16mm
what else?
coolant? screen wash? dv? any thoughts i want to do in 1 shot as postage at £6 ant cheap really.
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
well, you can use 3 or 4 mm for dv and fpr, 3mm is better imho as the nipples under the inlet mani are tiny and 3mm is just a little tighter, but its up to you. if you look at my bay, i have used only 8mm and 3 mm.
the 6mm in my bay you wont need as it for my mbc
infact get 1 m of 6mm. this is to go grom n75 valve to charge pipe, i did use 8mm before but 6 is a better fit.
so your list should be
2m of 8mm
2m of 3mm
1m of 6mm
itfben
DsignVinyl.com
Oct 24, 2009
2,000
nr. Tunbridge Wells
also, Robbie has blue tube down the far far left hand (drivers) side what would that be?
sambryant
Mar 26, 2009
4,848
Bristol
just edited my post. well my 3mm of hose is allowing 285bhp on a tough dyno so im happy :) just make sure you get good quality hose.
mbc is a manual boost controller, my turbo was spiking at 2 bar eeek. now runs at 1.4 bar all the way to the red line :D
itfben
DsignVinyl.com
Oct 24, 2009
2,000
nr. Tunbridge Wells
O right cool I might get a boost gauge at some point, that needs to be quite long doesnt it for boost gauge to run all the way in to the cabin?
thanks bro
sambryant
Mar 26, 2009
4,848
Bristol
I used 8mm as i already had it. Imho these vacuum pipes need to be a tight fit, even more so on a mapped car. U have the pic and sizes, if you like what you see just buy the same, simples
itfben
DsignVinyl.com
Oct 24, 2009
2,000
nr. Tunbridge Wells
cheers sam, well merlin motorsport dont do 10mm vacuum hosing anyway. I will go with your original list matey.
2m x 8mm
2m x 4mm
1m x 3mm
(will do boost gauge piping later down the line)
the last thing is is eBay the best place for clips and if so what type is best to go for i see you have two types of clips in your set up?
will order vacuum hoses now... seing as its a 4week dispatch time and i hoping i might get lucky and it will arrive before sunday the 26th June haha :D
itfben
DsignVinyl.com
Oct 24, 2009
2,000
nr. Tunbridge Wells
Oh great! :( Merlin Motorsport contacted me this morning saying they had none of my order in
Stock and that i have to order 3m length when ordering it in. Its guba take 4-5weeks :S
So should a knock off the 3mm stuff and use 4mm stuff that we in turn dave me having to but and additional 3m? or is it rrally worth getting the 3mm stuff?
