312 mm brakes
burns
hi ppl just asking really
want 2 get the 312mm brake kit off golf turbo . com
but wondered what seat dealers are like when it goes in 4 possible warrenty work
ie not going 2 throw the claim out cause of bigger discs :confused: :confused:
cheers 4 any input givin
mrcoyote
See no evil...
Jul 26, 2004
2,624
It's not just bigger disks, it's different calipers as well. I think under the EU rules, they're not allowed to invalidate your entire warranty, just the parts directly affected by any modifications you've made to the car.
Saying that though, I never had any problems when I had my old Ibiza which was just a littled modded...
Fez boy
560
Watford
Visit site
The 312 kit is so much better than the standard set up ;)
As mrcoyote said it may/will only affect thoses parts :)
IMO you will be saving them from doing any warrenty work :D
MagicFR
94
Manchester
Bare in mind that to upgrade to a 312mm setup you only need the brake caliper carriers and 312 discs obviously:)
Calipers you can use the same ones
Although money wise its defo a better deal by far to buy the whole lot from this chap
Triple D
:wtf: do you know what your talking about?
you need to change the discs, pads, calipers and maybe the hoses but the hoses should be ok
MagicFR
94
Manchester
I believe I do, but if you think I am wrong then I would appreciate it that you correct it me in a more polite way!!!
Calipers from an FR can be used on the 312mm conversion!!! At least they do fine on a few I've seen.....
WeeJase
pert
Jun 2, 2001
8,595
whats the disc size/pad thickness/hose length on the original setup?get this wrong and warranty won't be your concern,staying out of a headge might be,never enter into changing your brakes lightly,if you don't know,then consider getting someone to do it for you.
Triple D
MagicFR
94
Manchester
No need to apologise mate...after all this site is well known for some of its unhelpful members....plus some of them being a bit rude and big headed
but heyho at least u get a variety on the web
Triple D
I'm sorry if you got offended by that MagicFR i was just feeling a bit mischeivous. no hard feelings. As for me being unhelpful i think you'll find that your incorrect i have this particular braking system fitted, and i was iirc the first member to have this fitted to an Fr. i have over sixteen hundred posts to my name, Most of them Usefull information, some of them entertaining and a select few not usefull in the slightist. i would suggest when you decide to make your snap judgements at people you first take into concidration my loylty to seatcupra.net.
