Wear them in and see if you get problems after then.
as said before they will be greasy ad do take time to wear in.
also they are contis so not as gripppy?
lower profile means also may be more sensitive to bumps...
The rolling radius will have changed, (by about 30mm?) whether this would cause problems would depend on how the traction control is designed and activated...
for example, i believe some systems compare the drive wheels with the non driven wheels and compare the respective speeds.
so in a front drive car it compares the front wheel speed to the rear one and if the difference is over a set amount then it cuts in.
im NOT convinced it will be this system though as this wont work on 4wd and so id imagine another system is used. probably using ABS signal somehow.
however if you have changed the front and not backs then the radius of the fronts will be different to the back ones... - however its not cutting in unless its full on throttle so im not sure this is whats causing it.
lol so this wont be any
help but ill post anyway
