Just wanted to know what people think are the top 5 mods to enhance the performance of your tdi's. Take into account bhp/torque increase per £
Take it number 1 is a remap ??
m0rk said:doesn't increase bhp, but makes the car faster
Suspension
Brakes
Indeed.. I was sure to get these sorted first, before moving on to the power side of things.. I still haven't really 'moved' yet thosssstew said:yep totally agree. but all too many people over look these in the search for hp.![]()
muddyboots said:On Mk4 Ibiza and Fabia 130s, if you get a remap tailored on a RR (such as by Jabba), then fit the Cupra 160 air intake first, as the remap will be able to make use of the improved airflow.
From what I've read, Jabba reckon they can gain up to 10bhp more with the bigger air intake fitted, as they can hold the power longer at high revs. Some Jabba'd 130s are reaching 190-195bhp. You could also get the torque peak limited too, which will help preserve your clutch.
Considering the intake costs less than £30, that's an extra 10bhp for not a lot extra.
If you fit it after a remap, or don't use a "tailored" map, then the gains from the intake won't be as big.
muddyboots said:Just going on what I've read...apparently I heard the guys at Jabba were so impressed they were going to keep a stock of the intake pipes ?
I agree it does sound like quite a lot though.
You've been over in the UK then Paulo ?
prc said:It would be alot quicker because of the speed you can take into corners and the latter braking you can do.,
pbirkett said:Hellfire got 195 bhp out his Fabia vRS with a Jabba remap and Cupra intake. The normal going rate is about 185.
You cant use the Golf as a benchmark because it has better breathing as standard than a Fabia/Ibiza.
