Rain sensor in KL mk4 Leon?
Excuse me. What is that means? Thank you.
it means your car doesn’t currently have auto wipers, 8N6 is with automatic lights and wipers.
Try the changes I listed above. If it works then ETKA & parts link are correct and you have the correct sensor
If it doesn’t work then ETKA & partslink are wrong (to be fair partslink data comes from the same system as ETKA), and you don’t have the correct sensor installed. Install the correct sensor and with those coding changes everything will work
Feb 21, 2025
15
Thank you. This code in the photo must be active? Asked gpt and said it must be inactive.
Lastly, I need rain sensor and wires? And ideas that are the part numbers and from where could i buy a kit? I find it very hard to remove all trims and mirrors in this car
Thank you
The list I gave you is a car without vs a car with
The minimum you’ll have is a humidity sensor. The wiring will be there. The part number is on both of the screenshots I posted highlighted in bold text
Try the list I gave you, if it works then great. If it doesn’t, order the sensor and install
There's coding in A5 too, in addition to the list I posted
