I don't really have a proper scan tool sadly. Was thinking of just getting the basic £50 ODBEleven dongle which I believe can at least do a full scan in a similar way to VCDS. I know there are a ton of knock off VCDS dongles and hacked software out there but i'd probably steer clear of most of them to be honest unless anyone has any specific recommendations. At least then I can pull proper vehicle data out.
Without the
Obdeleven Pro license it will do the normal scans. The apps which are "micropayment" ones you can do certain things but I discourage their use. They are black box solutions which if they go wrong you can leave the cars
coding in a
problem state. Micropayment apps are like Excel macros which go off and trigger a sequence of commands.
Coding the commands are under your control so you can reverse what you have done. That's the Pro license. They are really toggles that you change. It keeps a record of what you have changed and you just undo them. The micropayment apps run a macros to do the toggling but if the toggles are wrong and changing back is wrong... it was put in by
Obdeleven to cover the other one click app market so it does both. You can always not renew the Pro license after doing any
coding you want to do.
Anyhow I'm wondering whether if it's a secondhand car or not a dealer may not have done an update to one of the modules if an issue had been found, That's the
problem of getting a car serviced outside the dealer network issues won't be fixed. Generally a dealer will say there is some
coding that needs to be changed, sign here or not on the annual service. If it isn't a good dealer they may not pick up on the work that needs to be done. So that fault that has come up on the dealer network and fixed by reprogramming the
coding or firmware update in the module gets missed.
The car runs a distributed control system. Each unit runs its small logic system. It's those that coders reprogram or the firmware if the lot gets changed in the device. Our 70s computer science lecture got excited about distributed control systems... well it was the school of applied sciences we went to for these lectures. Parallel processing was another one he got excited about... and Arcnet.
. Lexicon analysis another
... now you have all of it.
I'd report the issue to the dealer and see whether they know about it or try a different dealer. Their tech guru is suppose to be up to speed on known issues if you don't make any progress. Clearly it's a fault.
