£1.80 from TPSThanks for pointing that out, I just looked at mine and it's missing as well !!! About £7 to £9 now.
Looks much tidier in fairness! The bare inlet manifold is quite uglyHmm, have gone down a rabbit hole after seeing the engine bay mods and found this Golf R lower engine cover:
Genuine MQB Lower Engine Cover - 06K-103-925-AA – Progressive Parts
This Genuine MQB Lower Engine Cover for the 2.0T Gen 3 Engine helps to finish off the design of your engine bay in minutes. 06K-103-925-AAprogressiveparts.com
Looks a lot tidier than the bare inlet manifold.
1st engine bay mods
its only taken me 6 years but finally made some updates under the bonnet!! Lower engine cover & Racingline turbo elbow/pipewww.vwroc.com
From what I can make out online the cover comes with the ball joint and grommet to screw into the manifold to hold it in place.
Might order one when I'm back home next week...
Haha @Frostybear , I thought you'd react to that post!Looks much tidier in fairness! The bare inlet manifold is quite ugly
Dammit, broken the bank by paying £1.86 from Seatpartsdirect£1.80 from TPS![]()
1st engine bay mods
Here is a pic of my before and after, the oem shifter is horrible and doesn't even say dsgReplaced the DSG shift knob. The black interior could use a little spice, and this was exactly what it needed.
More pics + end result in my RR:
ND-Photo.nl 's - Seat Leon ST Cupra 280
Performed spark plug change and went with Bosch OEM replacements. The spark plugs looked ok to me, but the 2 middle ones had some soot on them. After swapping them out, the engine feels just that little bit smoother. I used a very light coat of ceramic paste on the outside, to keep the coil boot...www.seatcupra.net
Yes Yes Yes, you know you want to, Had one fitted many many years ago
TPS won't supply to the general public, been retired from the trade for 20 years this May!£1.80 from TPS![]()
Didn't think of trying themDammit, broken the bank by paying £1.86 from Seatpartsdirect![]()
You are a bad man, I love the OEM look of that R600 setup!
Postage not included, but they are my local dealer, and the car's going in for it's MOT on Monday so will pick it up then, along with the funnel washer bottle filler cap.Didn't think of trying them, did that include postage?
It has been a very long time since I had the R600 but from memory its the same as stock from a noise perspective.You are a bad man, I love the OEM look of that R600 setup!
I'm in the middle of upgrading my rubber fetish and mask-wearing gear at the moment (see my avatar for avoidance of ambiguity!), specifically the air supply, so would need to choose between lungs or combustion chambers if I were too tempted by the R600
In all seriousness, how much louder is the R600 over stock? I like the quietness of the standard setup as I do long motorway journeys, so wouldn't want a racing theme tune or drone when cruising, but would like a little more 'excitement' when putting the hammer down. And, does it offer any real performance improvements over stock? My intention is to go Stage 1 remap when the car's out of warranty, so am guessing this would be a complimentary piece of hardware?
Thanks,
Nick
