Low dust brake pads
WozzaB
26
15
Hi,
The brake pads are due to be replaced on my 2017 1.4tsi soon, I'm thinking of getting a set that produces less dust, I had a quick search on here and didn't see any recent info.
I've seen EBC green stuff and others, but there's so many brands and options and it gets a little confusing, so if anyone has any recommendations that would be appreciated
nd-photo.nl
3,958
174
The Netherlands
youtube.com
Ceramic pads give the lowest brake dust. Performance is also a little bit different than standard pads. Standard pads have a more initial bite and ceramic pads have a more linear bite.
Jurid and ATE will probably have a Ceramic solution for your car.
WozzaB
26
15
Thanks for the info, I'll have a look
Reactions: nd-photo.nl
WozzaB
26
15
I am an avid fan of ATE Ceramic pads, used them on all my vehicles for years, except my van because van, and they are as described, including low dust.
I was just looking at the ATE ones, they seem to fit the bill nicely and seem reasonably priced as well
SuperV8
1,659
775
I was going to comment that generally NAO's (ceramics) struggle at higher demands than low mets - and then I saw this from ATE's website FAQ's - interesting that they state:
The ATE Ceramic is not suitable for high performance or racing! The brake pad has been designed for use in normal road traffic and offers a longer service life, less noise and significantly reduced brake dust formation on the rims under normal driving conditions.
ATE Ceramic brake pads are designed for drivers who demand comfort. Under these driving conditions, the brake pad offers longer brake pad and disc life, less noise and significantly reduced brake dust on the vehicle rims.
As a matter of principle, we do not recommend using the PowerDisc or perforated brake discs in combination with ATE Ceramic brake pads.
Whenever I have tested NAO's they generally struggle at higher speeds/loads (fade testing for example) and generally have a lower mu compared to low metailcs, but this is severe testing, and would agree for normal road use would be fine. Just no autobahn top speed runs, or heavy towing etc..
WozzaB
26
15
That's good info, cheers.
I'm completely new to ceramic pads, but they do seem a good choice as they'll be used for normal daily driving with the odd bit of right foot where possible/legal, but that's rare these days to be honest.
Producing less dust is mainly what I'm after, apart from the braking performance of course.
