Cupra Sub8 wheels ET50 to Cupra R ET45
Tinbum51
53
Hi everyone,
Im running Sub8 wheels 235/335/8J19 ET50, with 10mm spacers rear and 5mm front. Car is tracked and adjusted to setup.
Wanting to fit OEM Cupra R wheels same size spec/width but ET45.
Am I right they will fit?
To get the same stance as currently, will I need a 5 mm rear spacer and no spacer up front?
Any advice appreciated lol!
serdar_18fr
398
Hi everyone,
That's correct. If you keep the existing spacers, wheels will extend 5 mm more to the outside.
Sent from my 23113RKC6G using Tapatalk
TheSwede
362
205
Sweden
You have another OEM alternative with ET40, also from Cupra R, not ST but the 2018 hatchback. Just a suggestion :).
As you can see from the backside it’s ET40 and the item no 5F0071499E. Then you can skip the spacers. I have bought two of them and used this Item no as a spare part when I scratched them a couple of years ago.
Reactions: H Rafiq
