Tavascan slow charging at home with Pod Point 7KW charger?
Jan 20, 2025
Hi, I have set a schedule to coincide with overnight cheap electricity tariff. The car is only utilising around 7 miles/hr to charge. Around 2.2KW/hr
When in immediate charge process it goes up to 24 miles per hour utilising the full 7KW/hr output.
Does anyone know the reason for this?
Tell
There have been some moans about Intelligent Octopus charging.
If you are using Intelligent Octopus, it might be that. You would expect it to be consuming 7kW/hr. If you have Octopus and haven't got one of their little free purple boxes (Octopus Home Mini) you might want to get that. It shows in real-time what is being consumed and the price. Integrates with the Smart meter radio signal and the Octopus app. You will see exactly what is going on in the 30-minute intervals and in real time.
If not it could be your charger unit / software and connection. There are those limits where you can cap charging to a given level. Start charging immediately, may go above those set limits.
You might find something on the Born thread and wider Googles on VAG hardware. There have been moans, I know that. I don't have an EV, but I am keeping an eye on the subject for when I do. There might be a more well versed expert on this one.
Jan 20, 2025
Thanks, I don't use Octopus. Eon, with Pod Point charger. Worked fine with a Kia Nero 2, just using the schedule from the charger, but the Tavascan needs to be in control of its schedules it would seem. I have contacted Cupra for help.
Reactions: Tell
Tell
That might have one of the ones I'd read. 🫢 Certainly mutterings about charging. Keep us up-to-date.
