Which Brake pads? Confused about models and PR codes
Greetings from Sweden,
Since November i own a 2019 Seat Leon Cupra ST300 ( VIN nr. VSSZZZ5FZKR038797). I like the car so far, but only driven it 500km before brakes gave up. I now want to change discs and pads, both front and rear.
I ´ve tried searching for what brake setup my car has, and how to navigate with PR codes and different brands of manufacturors - but i cant seem to find any 100% certainty..
Front brakes i got marketplace, but rear brakes i ordered new, and can return/change if needed. I might have been too quick buying stuff, because i cant wrap my head around these PR codes. None of mine seem to match. Anyone know if this setup will fit my car?
Thanks in advance.
/Martin
serdar_18fr
494
Thanks in advance.
/Martin
Hi Martin
Here's the parts list for your car:
FRONT (PR codes: 1LD or 1LJ)
5Q0615301G Brake disc vented 340x30mm x2 units
5Q0698151AJ Brake pads with wear indicator x1 set
REAR (PR code: 1KY)
5Q0615601E Brake disc vented 310x22mm x2 units
3Q0698451N Brake pads x1 set
--or--
5G0698451A Brake pads x1 set
Hope this helps & best regards,
Serdar
