OBD11 draining battery
Jan 14, 2025
11
Hi,
I bought my Seat last week and an obd11 along with it.
After driving around a bit I wanted to change how some settings behave so I connected the obd, went through the setup like normal and did a scan.
For some reason when I have the obd connected for about a minute I get a warning "low voltage: battery below 12V" and the car won't start.
Doing a push start will get it going and if I drive a bit it'll start on it's own.
I tried connecting the obd again after driving 2 hours and the same thing happened.
Is my battery dead? Or is the OBD messing with something.
by the way for connecting:
Connect OBD
put the car on ignition but don't start it.
Open the app and do the scan
After scan I have about 30-40s then the battery dies.
any help?
cairus
1,529
540
no, complete view where you can read everything that is written on the battery
Jan 14, 2025
11
Why do you assume the dealer swapped the battery out? Was there an issue with the battery before you bought it?
You were right he didn't swap it.
My battery was from 2017 and it didn't start again this morning.
Got a replacement battery and the dealer I bought the car from will pay it.
I'll try the obd again after driving a bit to make sure it has some juice, thanks anyways!
nd-photo.nl
4,394
476
The Netherlands
youtube.com
I can highly recommend everyone to add a battery monitor to their battery. Gives insight in what is happening (y) On my previous car it helped me with finding a battery drain.
More info: https://www.seatcupra.net/forums/threads/nd-photo-nl-s-seat-leon-st-cupra-280.477591/post-5068748
Link: https://www.amazon.nl/-/en/Battery-...oring-temperature-notification/dp/B00ZETXNAQ/
AP1GczOP1YtbHVc94hGuOFaOlnnOaBx24PUv2CgRLjw5gf0-Din_o4OQ2Jrr81kt_DpXiTiDl09OXC-zWsH1RGfR6sECSGXvKmdL9w66_ra2yEik4njFB1CvuAjcmFBKWWVjFTq7MqkSNdlgpVk08Sn2EFgB-g=w1920-h1080-s-no
Big Vinny
237
59
If you replace the battery you will need to use your OBD11 to "code in" the new one if you fitted your own battery or the garage hasn't done it. There are threads and YT clips on how to do this. It's pretty straightforward.
One of the first signs of a failing battery is "stop start" will not work. I believe if the battery does not store over 80% of its programmed maximum charge it will not work and you get the stop start crossed out symbol on startup.
Reactions: nd-photo.nl
tracktoy
807
651
Just to add I have my OBD11 Dongle plugged in all the time (for well over 5 years) with no issues on battery draining.
However OBD11 do recommend you log off the car after using the dongle just to ensure you dont leave any control units running.
Reactions: Cubbington
Jan 14, 2025
11
the guy who replaced my battery did program it in the car.
From what I remember he changed the Ah from 65 to 60 and he set the serial number? (10 numbers) from whatever it was to 1111111111
But the new battery does work, start/stop is functional, no more low voltage warnings and I connected my obd yesterday it works like a charm.
Managed to change almost all the settings I wanted except for 2 which I'll do some research on tomorrow.
