Suspension Repair Question - Need Advice
Nov 24, 2024
7
Hey everyone,
I’m looking for some guidance on a suspension repair issue I’ve been dealing with.
My car has started making a strange noise when going over bumps, and I suspect the suspension is the culprit.
I’ve checked the struts and shocks, but I’m unsure if other components could be affecting the performance.
I’ve heard that worn-out control arms can cause similar issues, but I wanted to ask if anyone has experienced something like this before.
Any advice on diagnosing or fixing the suspension would be greatly appreciated.
Nov 24, 2024
7
Hey everyone,
Any advice on diagnosing or fixing the suspension would be greatly appreciated on Flooded Alfa Romeo repair services in Dubai.
thanks in advance for any help
Guyelle
49
21
What kind of strange noise, how would you describe it?
It could be many things: droplinks, track rod ends, control arm ball joint, worn control arm bushings, worn top mount, broken spring, failed shock absorber. Could be many things, best way to diagnose is jack it up, get the wheel off and check for play in the bushings and balljoints with a pry bar. A failed shock or broken spring you can usually spot by eye.
What car is it?
