Model Year 21/22 Lane assist
May 2, 2024
Hello ,
Is there a way of permanently switching off the Lane assist function ? Have to do it manually on every journey and how do I check if the latest version of the software is currently installed ?
CupForm
144
75
Bucharest, RO
It is possible to set it to On/Off/Memory when the car is started; it can be done via OBD11 or VCDS. So try to find someone close to your location that already has one of the two.
Karbonfaiba
184
115
Hampshire, UK
Purchase OBDeleven NextGen and 20 credits - Activate Lane Assist Setting Memory (enables it to remember last setting) then deactivate Lane Assist Information Message - the warning message that stays on if lane assist is off.
On a personal note; the lane assist on MQB Evo vehicles is less intrusive than it used to be, when passive, I don't recommend turning it off. Maybe because I'm a diehard travel assist user, I think it's one of the better more confident active lane hold systems from 2020 onwards.
System information (in the settings menu I think) will tell you the software version. 1969 is the current latest for the Formentor.
cairus
1,146
409
Your information should be entered with caution because there is a deadline when even OBD11 can no longer carry out these settings.
CupForm
144
75
Bucharest, RO
If the car is a Facelift model, it has SFD2 - therefore it cannot be unlocked AFAIK. For pre-facelift models it's still ok; basically for all models of the group using MiB3 it will be ok. For the updated/facelift versions using the newer protection it cannot be done yet.
cairus
1,146
409
I don't mean SFD. I know it from Skoda, it hasn't been working there for a while
the storage is not done via the MIB
